Hi guys, I’m getting my monophonic mono synth into my pisound audio in but I only get one sound in the right ear. Is there something I’m missing as far as configuration goes? Thanks for your help.
Hi, the ports on Pisound are stereo ones - if you plugged in a monophonic device, only the tip of the jack is used to transmit the signal, and it ends up in the left stereo channel.
To convert it to stereo in MODEP, simply use multiple connections of the left channel input to where it needs to go.
Thanks a lot @Giedrius it was fairly easy after all…
