hi,
how can i manually install amidithru on a raspi 4 aarch64? is it possible?
Thanks
hi,
Thanks
You can install from source code: GitHub - BlokasLabs/amidiauto
It should be done something like this:
# Install required library
sudo apt install libasound2-dev
# Get the source code
git clone https://github.com/BlokasLabs/amidiauto.git
# Build and install
cd amidiauto
make CXX=g++
sudo make install
Check if it succeeded:
systemctl status amidiauto
i was searching for amidithru… because i need it to create a virtual midi port…
is it possible also with amidiauto?
My mistake, do pretty much the same with this repo instead: GitHub - BlokasLabs/amidithru: User mode ALSA MIDI thru port.
