No. That is not right. It sends quarternote pulses. With no meassures. If you absolutely want to use 4/4 as an hypothetical example, it sends all 4 quarternotes in a bar.
It’s just that I don’t need the meassures. I’m not implementing song position or anything like that. What I want is other gear to relate to a pulse. Hence midi beatclock
btw what’s the logic behind the display when it’s Sysex, Giedrius?
It seems to travel across f0 00 01 74 10 10 f7 using the Outgoing too, repeating every word except 74 (the ‘unit number’?)
The SysEx are handled in chunks of up to 3 bytes in length, so that’s why it’s printed this way.
The Outgoing display seems to have a bug, it should show the same events as Incoming. Could you double check if the correct SysEx output is physically sent and the issue is only the display by monitoring a looped back port, or some other means?
The sending itself is fine, Giedrius,
I had MH acting as a go-between with a hardware seq → MH† → DAW
so’s I could more easily record a .mid for @Honken (without resorting to floppy disks!).
Input & Output same
The screenshot is Sysex from his Axe, his monitor matches mine.
†pipeline was literally MIDI-IN → Filter(all but Sysex) → USB-OUT
