hi dormir,
nice to hear from you. I looked briefly into your code. many things to learn for me.
I will try to try it out in the next weeks.
currently I am exploring the midihub together with a digitakt and an external controller, more or less for similar duties I have made my sc program with the akai midimix for: recording something into a buffer and manipulating it, trying to shape something that pleases me - all in that and for the moment.
my pisound setup was:
I used patchbox and as audio interface a tascam dr40, the akai midimix and a thyme.
Together with this sc code:
'main-akai+playbuf+reverb-4-1-6-2'
6 tapemachines
2 warpmachines (slight random position function)
2 reverb groups
group 'left' and 'right' with 3 tapemachines and 1 grain-warp-machine
// LEDs (noteOn value) and cc value (every fourth) akai default values
var muteled, recled, bankled, sololed, cc;
muteled = [1, 4, 7, 10, 13, 16, 19, 22]; // note values
recled = [3, 6, 9, 12, 15, 18, 21, 24]; // note values
bankled = [25, 26]; // note values
sololed = [27, 0]; // notevalue
muteled = Array.fill(8, {arg i; Array.with(muteled[i], 1)});
recled = Array.fill(8, {arg i; Array.with(recled[i], 1)});
bankled = Array.fill(2, {arg i; Array.with(bankled[i], 1)});
cc = [16, 20, 24, 28, 46, 50, 54, 58]; // 1st cc value of row. every row has 4 ui elements - akai
// cc = [0, 4, 8, 12, 16, 20, 24, 28]; // 1st cc value of row. every row has 4 ui elements - faderfox ec4
a = Array.fill(8, {arg i; i }); // buffers
b = Array.fill(8, { arg i; i }); // rec synth
c = Array.fill(8, { arg i; i }); // play synth
s.options.sampleRate = 48000;
s.waitForBoot({
MIDIClient.init;
Platform.case (\osx, {~midi = 1; MIDIIn.connectAll}, \linux, {~midi = 0});
~rate = [
(-12.midiratio*(-1)),
(-19.midiratio*(-1)),
// -1,
// -0.5,
-24.midiratio,
-19.midiratio,
-12.midiratio,
-7.midiratio,
-3.midiratio,
1,
3.midiratio,
7.midiratio];
// ~rate = [-1, -0.5, -0.25, 0.5, 0.25, 1, 1.25, 1.5, 2];
~dur = s.sampleRate * 8;
~dursec = ~dur/s.sampleRate;
~waitbus = Bus.audio(s);
~outbus = Bus.audio(s);
~reverbbus = Bus.audio(s);
~midinote = {arg led, state; MIDIOut(~midi).noteOn(0, led, state)}; // function to set button lights (LEDs)
s.freeAll;
/* Buffer and MIDI setup */
Buffer.freeAll;
8.do({arg i; a[i] = Buffer.alloc(s, ~dur)}); // 6 buffers to record external signals
s.sync;
/* SynthDefs */
SynthDef(\play_tape, {
var sig;
sig = PlayBuf.ar(1, \bufnum.kr(0), \poti_1.kr(1) * BufRateScale.kr(\bufnum.kr(0)), Impulse.ar((~dursec/\poti_3.kr(1)).reciprocal), ~dur-\poti_2.kr(~dur), 1);
sig = sig * \fader.kr(0.2);
Out.ar(\out.kr(~outbus), sig);
}).add;
SynthDef(\rec, {
var sig, play;
sig = SoundIn.ar(0);
play = RecordBuf.ar(sig, \bufnum.kr(0), \offset.kr(0), \reclev.kr(1).varlag(0.3), \prelev.kr(1).varlag(0.3), \run.kr(1), \loop.kr(1));
}).add;
SynthDef(\play_warp, {
var sig;
sig = Warp1.ar(1, \bufnum.kr(0), (\poti_2.kr(0)) * BufRateScale.kr(\bufnum.kr(0)) + LFNoise1.ar(0.6).range(-0.1, 0.1), \poti_1.kr(1), windowSize: \poti_3.kr(0.1), overlaps: 4, windowRandRatio: 0.1);
sig = sig * \fader.kr(0);
}).add;
SynthDef(\verb, {
var sig;
sig = In.ar(~reverbbus);
sig = GVerb.ar(sig, \roomsize.kr(91), \revtime.kr(0.1), \damp.kr(0.1), drylevel: \drylv.kr(1), earlyreflevel: 0.9, taillevel: \taillevel.kr(0.3));
sig = sig * 0.4;
}).add;
SynthDef(\outbussynth, {
var sig;
sig = In.ar(\in.kr(~outbus));
sig = Pan2.ar(sig);
Out.ar(0, sig);
}).add;
s.sync;
/* Synths */
y = Synth(\verb);
x = Synth(\outbussynth, addAction: \addToTail);
// 'rec' synth
8.do({arg i;
b[i] = Synth(\rec, [\bufnum, a[i]], addAction: \addToTail);
// 'play' synths
[1, 2, 3, 4, 5, 6].do({arg i;
c[i] = Synth(\play_tape, [\bufnum, a[i]]);
[0, 7].do({arg i;
c[i] = Synth(\play_warp, [\bufnum, a[i]]);
s.sync;
/* MIDI */
// LEDs default on
8.do({arg i; ~midinote.value(muteled[i][0], 1)});
8.do({arg i; ~midinote.value(recled[i][0], 1)});
2.do({arg i; bankled[i][1] = 0; ~midinote.value(bankled[i][0], 0)}); // reverb leds off
// encoder and faders
MIDIdef.cc(\tapemachines, {arg val, cc_value;
case
{cc_value == cc[i]} {(c[i]).set(\poti_1, (~rate[val.value.linlin(0, 127, 0, ~rate.size-1)]))} // pitch
{cc_value == (cc[i]+1)} {(c[i]).set(\poti_2, val.value.linlin(0, 127, ~dur, 100))} // start position
{cc_value == (cc[i]+2)} {(c[i]).set(\poti_3, val.value.linlin(0, 127, 0.6, 42))} // start reset LFO
{cc_value == (cc[i]+3)} {(c[i]).set(\fader, val.value.linlin(0, 127, 0, 1.2))} // vol
MIDIdef.cc(\warpmachines, {arg val, cc_value;
[0, 7].do({arg i;
case
{cc_value == cc[i]} {(c[i]).set(\poti_1, (~rate[val.value.linlin(0, 127, 0, ~rate.size-1)]))} // freqscale
{cc_value == (cc[i]+1)} {(c[i]).set(\poti_2, val.value.linlin(0, 127, 0, 1))} // pointer to the buffer
{cc_value == (cc[i]+2)} {(c[i]).set(\poti_3, val.value.linlin(0, 63, 0.1, 1))} // windowsize
//master fader for verb
MIDIdef.cc(\akaimmix_cc_master, {arg val, cc_value;
if (cc_value == 62,
{y.set
\revtime, val.value.linlin(0, 127, 0.1, 28),
\taillevel, val.value.linlin(20, 127, 0.2, 0.7),
\damp, val.value.linlin(0, 50, 0.5, 0.1),
\drylv, val.value.linlin(50, 127, 1, 0.4)
//buttons
MIDIdef.noteOn(\akaimmix_btn, {arg val, note_value;
8.do({arg i;
case
// mute btns
{(note_value == muteled[i][0])} {
if(muteled[i][1]==0,
{muteled[i][1]=1; b[(i)].set(\prelev, 1); ~midinote.value(muteled[i][0], 1)},
{muteled[i][1]=0; b[(i)].set(\prelev, 0.3); ~midinote.value(muteled[i][0], 0)}
//rec btns
{(note_value == recled[i][0])} {
if(recled[i][1]==0,
{a[i].zero; recled[i][1]=1; b[(i)].set(\reclev, 1); ~midinote.value(recled[i][0], 1)},
{recled[i][1]=0; b[(i)].set(\reclev, 0); ~midinote.value(recled[i][0], 0)}
// recAll off button (solo)
MIDIdef.noteOn(\akaisolo, {arg val, note_value;
case
{note_value == sololed[0]} {
if (sololed[1] == 0,
sololed[1] = 1;
8.do({arg i;
recled[i][1]=0; ~midinote.value(recled[i][0], 0); b[i].set(\reclev, 0)});
sololed[1] = 0;
8.do({arg i;
a[i].zero;
recled[i][1]=1; ~midinote.value(recled[i][0], 1); b[i].set(\reclev, 1)});
// verb buttons
MIDIdef.noteOn(\akai_bank, {arg val, note_value;
case
{note_value == bankled[0][0]} {
if (bankled[0][1] == 1,
{bankled[0][1]=0; 4.do({arg i; c[i].set(\out, ~outbus)}); ~midinote.value(bankled[0][0], 0)},
{bankled[0][1]=1; 4.do({arg i; c[i].set(\out, ~reverbbus)}); ~midinote.value(bankled[0][0], 1)})}
{note_value == bankled[1][0]} {
if (bankled[1][1] == 1,
{bankled[1][1]=0; 4.do({arg i; c[i+4].set(\out, ~outbus)}); ~midinote.value(bankled[1][0], 0)},
{bankled[1][1]=1; 4.do({arg i; c[i+4].set(\out, ~reverbbus)}); ~midinote.value(bankled[1][0], 1)})}
}) // s.waitforboot BLOCK
)// all BLOCK
I even tried to use github as you suggested, but did not manage to proceed.
best regards
