Hello everybody!
I’m a newbie, so sorry for silly questions!
I have a python script to translate Qwerty keyboard keys in midi signal, perfectly working. I need it to automatically execute after Jack has been loaded. I tried several ways and I always end to start it before Jack, I can’t figure out a way to fix this…
Thanks to everybody for help!
Thank you! I fixed using the .bashrc method.
Hey, what is the .bashrc method?
I found a good explanation here (second method): https://www.dexterindustries.com/howto/run-a-program-on-your-raspberry-pi-at-startup/
It’s not the best way ever, since it start everything every time you open a new terminal (for example via SSH), but for me it’s ok! I will add my script on GitHub and an easy tutorial cause I think that this can be useful for other people!
You may make the Pisound button to execute your script, in case you wouldn’t have a way to access the terminal.
