In the image you posted - look at the bottom pane of the window. This shows some errors with alsaaudio. I think it’s because you don’t have a default audio device defined. I’m not sure how that is setup on pisound.
EDIT:
on a regular Raspi I would setup the default audio card with the following:
create asound.conf
sudo nano /etc/asound.conf
then add
pcm.!default {
type hw card 0
ctl.!default {
type hw card 0
Yes, this is the way, you have to also figure out what is the Pisound’s card number, you can do so by running aplay -l, usually it’s 1 or 2, 0 is usually the built-in audio (analog & HDMI).
Thank you so much for taking the time to help out!
I have a very busy day today, hopefully tomorrow I will have time to try it out. I’ll make sure to let you – and anyone interested who’s reading this – know if it worked.
Trying to install Eyesy on a RPi 3 with Pisound hat.
Followed the installation walkthrough but now I hit a wall after
git clone https://github.com/okyeron/EYESY_OS_for_RasPi.git Eyesy
cd Eyesy
./deploy.sh
the script stops with
+ sudo apt install -y python-pygame python-liblo python-alsaaudio python-pip libffi-dev nodejs
Reading package lists... Done
Package python-pygame is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
Package python-liblo is not available, but is referred to by another package.
Package python-pip is not available, but is referred to by another package.
However the following packages replace it:
python3-pip
E: Package 'python-pygame' has no installation candidate
E: Package 'python-liblo' has no installation candidate
E: Unable to locate package python-alsaaudio
E: Package 'python-pip' has no installation candidate
So I followed the instructions you and @Giedrius provided and got the same error with the asound.conf settings on 0 + 0 and 1 + 1. However, on 2 + 2 something was different, it seemed like it was going to start but then failed, with the following message when launching a Python ‘script’ in the EYESY editor:
connected to websocket server
Started Python Pygame Video Engine.
pygame 1.9.4.post1
Hello from the pygame community. Contribute - pygame wiki
starting…
[‘main.py’]
pygame version 1.9.4.post1
opening frame buffer…
opened screen at: (1280, 720)
Fatal Python error: (pygame parachute) Segmentation Fault
eyesy-python.service: Main process exited, code=killed, status=6/ABRT
eyesy-python.service: Failed with result ‘signal’.
I feel I’m close… any idea what could be the issue this time?
Best regards and a happy new year to everyone (not expecting an answer right away, eheh)
EDIT:
Additional thought - what sound card/device are you using?
In my testing just now, if do not have a valid input/capture device, then python is going to error as it did initially for you. Note - a bare Pi does not have an audio capture device - only output.
I’ll see if i can add some better error checking for the audio devices and debug output.
What image are you starting from? Seems like there might be a python incompatibility?
I’ve got a patchbox install that is Linux patchbox 5.4.72-v7+ and everything seems to install normally.
use uname -a to get that kernel info.
FWIW - I’m just now tweaking a branch of the EYESY repo specifically for patchbox. The original repo assumes a bunch of filepaths for the pi user which don’t exist on patchbox installs.
If you have patchbox - you could add git checkout patchbox to the commands just before the deploy script to try this branch.
NOTE - in testing, you may need to disable pulseaudio in the patchbox config - under patchbox modules → pulse audio off.
Also - you may need to change line 43 in /Eyesy/engines/python/sound.py to 44100 if thats what your soundcard uses. Although I think you can leave it at 48000 for patchbox.
I followed the step-by-step guide and used the newest raspberry pi os lite image.
uname -a gives me Linux raspberrypi 5.10.63-v7+ #1488 SMP Thu Nov 18 16:14:44 GMT 2021 armv7l GNU/Linux
Should I restart from scratch with a diiferent os image or would it be easy to fix incompatibilties by installing missing dependencies (for a noob I am)?
I’m using a UGreen USB soundcard with input and output:
I’m doing all this on a Raspberry Pi, not a Pisound. I can try to run the aplay command and see what it gives me later today or within next few days for sure.
null
Discard all samples (playback) or generate zero samples (capture)
default
output
input
sysdefault:CARD=Device
USB Audio Device, USB Audio
Default Audio Device
front:CARD=Device,DEV=0
Front speakers
surround21:CARD=Device,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Device,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Device,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Device,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Device,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Device,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Device,DEV=0
IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=Device,DEV=0
Direct sample mixing device
dsnoop:CARD=Device,DEV=0
Direct sample snooping device
hw:CARD=Device,DEV=0
Direct hardware device without any conversions
plughw:CARD=Device,DEV=0
Hardware device with all software conversions
BTW, should I run these commands with audio going in? This command and the previous (aplay -l) I didn’t have any audio going in.
I used the 05/28/2021 Buster Image mentioned by okyeron above with my Pi 4B, PiSound, and TouchOSC. I followed the instructions and it works! Thank you! Sometimes the ‘trigger’ functionality or the input level meter doesn’t seem to be working - but a reboot corrects it. So far so good…
Would love to know if anyone has had success using the most recent Patchbox OS 11/23/20 image.
Hoping to find out if I should still try making this work or give up…
I did run arecord -L as you suggested and yhis is what I got:
null
default
output
input
Front speakers
Not really sure. I did some testing and then forgot whatever I might’ve learned.
It’s possible PulseAudio is installed and is being recognized as the default device no matter what. In my previous experiments I removed PulseAudio from the system to avoid problems.
“Started Python Pygame Video Engine.
pygame 1.9.4.post1
starting…
[‘main.py’]
eyesy-python.service: Failed with result ‘signal’.”
I think it’s a no-go. A bummer but I’ll repurpose the Raspberry for something else. Thank you very much for the support and willingness to help out, really appreciate it!
