You’re right, it still happens it seems.
I only had it happen once though, and I’m still not sure what causes it.
It’s kind of tricky to work it out though as I have quite a complex setup, but it’s the first time it has happened since I installed 1.13.
I have been considering rebuilding my presets from the ground up though just to see if I can simplify it (I have a lot of lanes that are no longer in use, and I don’t used virtual ports as much as I should when I first set this up).
That might help me make some new finds.
What I do know though is that this only happens if my synth has MIDI CC Receive on. Otherwise it doesn’t occur. Said synth is also the first in the chain on that particular output.
There’s however a good (? ) potential for midi feedback if some logic no longer works as expected.
I’ll stick to it and see if I can get any progress.
Nice to see port naming in this release, unfortunatly it can´t be done pipe by pipe as my INs come one time from the NDLR and on another time from certain synths. It depends on the midichannel in my setup, the ports have different inputs from different devices and I think it´s quite normal that you don´t need all 16 channels from a Port point to only one device.
Issue - arp doesn’t seem to be working properly at all.
It’s playing 1/2 to 1/3 of the notes, and the notes don’t seem to be playing at the correct time intervals or in the correct order.
Hi @uth, we test the firmware update on Ubuntu x86_64 and Raspbian ARM Linuxes, it is working just fine on our test devices. You can find a backup of the memory contents here:
~/.local/share/Blokas/Midihub Editor
Is there anything specific to your installation that could impact Serial / USB communication?
Do you have time to dig into this and provide some additional info? If so, I’ll send you a PM with details.
It’s just a laptop bought few years ago, with Midihub connected directly to the USB port. The laptop itself and the internet connection seem ok. If I recall well, there was a message “erased 50%” before the error showed up.
Yes I would want to debug this. This is the same unit where Microtonal occasionally loses its configuration (until restart, I wrote about it) so I wonder if the microcontroller is stable. On the contrary, the manual upgrade works in every case.
the unit never freezes, so maybe the microcontroller is ok
due to differences between octaves, I use scala files with frequencies separate for each MIDI note, up to 127, maybe this makes Microtone glitch occasionally?
So does it work ok in latest versions? If not, please create a new topic or revive the previous one to discuss details. If possible, a consistent way to reproduce the issue would be really helpful.
