Thanks a ton for sharing this! I’m trying to change the Prophet REV2 LFO 1 shape with a button on my KeyLab 88. On the REV2 panel there’s one button to cycle through the 5 possible LFO shapes. I’m performing a piece where I need to change directly to particular shapes without a different shape in between. On the REV2 panel for instance I would need to go though Saw and Rev Saw to get from Triangle to Square.
On the KeyLab the buttons have a switched control that sends a programmable CC value for on/off when set to a toggle, or in the gate mode it will send one value while pressed and another that could be filtered out with the Midihub when released.
Could I do this with two pipes similar to what’s in “CC to NRPN.mhp”? To change the LFO 1 shape on the REV2 MSB is 0, LSB is 38 and the possible values are course 0, and fine 0-4. So if I was transforming CC 57 for example to change the shape to Triangle (0). What would need to go into the pipes to make that happen?
BTW: I don’t see any notes in the description fields in “CC to NRPN.mhp”, so maybe they got lost?
Amazing! That does work perfectly for my application. I just removed the rescale pipe and the buttons send the 0-4 values. Thank you very much! There’s really not much that Midihub can’t do. What an amazing tool. All the best!
Thanks for this. I’m still figuring out midihub, so I’m not quite understanding the design of this file. Why do you change the CC to a ‘note on’ command and then from there into the output set of 3 CCs? Why not just transform the initial CC into the three output CCs? I feel like I’m missing something important but can’t figure it out. Any help understanding this would be greatly appreciated!
It’s necessary to use a different type than CC to avoid ‘CC explosion’, so note on is just an information carrier message for the rest of the Transform pipes. It could be any other non-CC MIDI message with 2 data bytes, like polyphonic aftertouch.
Btw, this MIDI Messages Summary is quite good quick reference on all the possible MIDI messages, it’s handy to quickly refer to, especially when transforming between types.
…meaning that a Transform pipe would act on everyWhat message that passed through it.
It’s worth bearing this in mind when looking at any Transform patch posted prior to 2022; sometimes, like here, you’ll see “extra” steps that needed to taken then but now – when the Channel, Data Range properties effectively allow filtering in the Pipe itself – can be simplified.
Now Transform truly is the Swiss Army Knife of Midihub pipes! (bravo Giedrius!)
@Giedrius point is a good one in terms of generality,
but, you’re correct, with “2022” Transforms you can just use CC → CC.
Moreover depending on your usage, you can map one of the Transform values if you wish
To use CC to CC transform, you must make sure to use the “Work with CC Number” parameters correctly, this is necessary to avoid what I called the CC explosion, where if “Work with CC Number” was not set up to work on specific IDs, every Transform that’s adding an additional CC would have more and more CC messages to work with, the first transform would end up forwarding 2 CCs, the next would multiply them to 4, the next one would provide 8, etc…
So in order to avoid this CC explosion, one way is to use an unrelated message type to carry information to the rest of the pipes that gets silently dropped from the stream once it is no longer needed, and another is to have correctly set “Work with …” parameters.
If you’ve still got the Zero SL that is an ideal tool for the task.
With that you won’t need to use Midihub to create RPN/NRPN messages like in the posts above; although MH might be useful to do a Transform for converting a “3 x CC Zero SL” message to a “MC303 Select Sound” message.
If you want to put together a partial list of the specific things you want to control and Message me,
I’ll try to give you some pointers. I have the Novation Mk1 (& an iffy Mk2!) if you’re going that way
The supplement tries to walk through just a few examples, do you have a full list anywhere? - only ref I see is the scanned full manual
Hey @resonotter,
Thanks so much for your response and offer
I thought I saw some other document online, but cant seem to find it - maybe I’m mistaken…
What I did come around while searching, and havent seen before, is this:
Do you have any experience with it? Seems old and outdated, but pretty powerfull, if it does what it promises haha
One thing I can say is, thanks to the midihub, I was able to integrate the MC303 in my setup, sequencing basic note (+velocity) information with the digitakt. The problemn before was, the MC303 receives all channels at all times. Since I could filter out one dedicated channel for it I was happy. But especially the part with “select sound” is very relevant, since right now I note down what “sound” of what “bank” I need to dial in manually.
Would it mean I could just dial in U06 (UserPattern), sound 4 for example? I use it in normal mode, so that I keep my own saved sounds.
At this point important to mention for anyone reading this, DONT just use module mode. I lost years of sounds I build on different UserPatterns, when figuring out how to set up that midi connection.
I also just have these 2 files. The user manual and the adv midi one. I would be happy to ping pong some tips and tricks together thanks for the offer! Maybe we could make a dedicated topic for it? Either simply “MC303+NRPN” or, thats what the midihub did for me here, “Giving life to old gear” a more general topic on how you learn to integrate certain hardware in you setup.
Sorry, didnt mean to jump to conclusion. Misunderstood you being a pro with the MC303
Thank you for your offer I def would be interested to learn from your novation skills. One pipe I havent been able to work with well (and saw you being a pro at) is the transform pipe.
Love your visuals already and gonna take my time to dive into it a bit more, before contacting you but I guess generally speaking I could set up the NRPN messages in the novation and controll them with one CC from somewhere else? That would probably be my goal anyways.
To your question about my other post, I guess I would want 1-4 parameters to use. Like the “commonly used”: PatternBank, SoundBank, FilterCutoff, FilterResonance
But the Banks being the most important and helpful once. As I said, right now I’m changing the sounds manually per pattern in my live setup, which is odd. Depending on the workarounds yes, my goal would be to have a less maxed out preset for sure.
Thanks for that. I keep meaning to go back to that tutorial and complete it.
( Giedrius made a couple of comments about my explanation strategy which made me go & rethink that aspect from scratch)
One pipe I havent been able to work with well with … is the transform
My hunch is that’s loads of Midihub users.
Once the penny drops, it’ll be your Swiss Army knife…
Just going to take another look at PatternBank, SoundBank…
I think its very true and I’m curious to see how this tool will unfold
here is the manual part with the midi implementations. I’m still trying to find if pattern, specifically UserPatternBank is even possible to control. It might be, that in the end I cant use it that much. I stated in a earlier post, sound module mode is no option for me. That would kill all my own sourced and saved sounds…
Also, thats fine too. If I could control like FilterCutoff and such, would be very cool already. I could make some automation and gain a lot of flexibility. For example to bring down certain parameters with pattern switches of my sequencer (digitakt).
Thanks so much already for your help!
Wishing you a great start in your week
