I currently have Sooper Looper on a pedalboard but I’m not a huge fan as it doesn’t really give me what I’d like. After a Google around I came across the ALO plugin (GitHub - devcurmudgeon/alo: A Looper plugin for MOD duo) which is now part of the GitHub - moddevices/mod-plugin-builder: MOD Plugin Builder and I’d really like to give it a try as an alternative looper but I don’t know how to go about building it for the PI and getting it integrated into MODEP.
I’ve tried to look at the mod-plugin-builder docker (details from [GUIDE] Many More Extra MODEP Plugins) but didn’t get very far as I struggled to get git working to update the submodules - kept on failing on network connections even though I’m using ethernet (not wifi).
Is there a simple way to get the plugin build for MODEP - it uses a .mk build file.
@Giedrius Finally had chance to try your solution and it’s built and installed and appears in the MODEP UI. Thanks.
Unfortunately, when the plugin is not in ‘bypass’ mode, no audio comes through or triggers starting the loop. Is there a way to debug/view logs to try and see why there is no output when the pedal is enabled.
@Giedrius Thanks. Was able to do a bit of debugging but in the end it my main problem was that the clock wasn’t triggering the pedal so never started. Once I’d figured that out, loop recording started. It still doesn’t play sounds through the pedal - only on playback of the loop so I just feed my instruments to both the ALO looper and the output.
Still need to play around a bit with it but seems to be working now. Thanks for your help.
@ElijahLynn if I understand correctly, Giedrius and Greg209 got it working, so it should be possible for you too
Can you confirm that you’ve got a global midi BPM clock running? Also as Giedrius mentions, note that Alo only outputs the loops, so you need to route your original to the output separately.
Thanks for the reply! I don’t see a global bpm plugin in Modep library. I’ll look for one and see if I can install it. I searched for “global” no results. It sounds like it might not be a plugin but a feature of Mod Duo. I am running an older MODEP, about 6-12 months old, so maybe it is in a newer MODEP image.
I setup the input to go to the output and Alo, then added a generator and linked that midi to Alo. Can you look at my screenshot and see if that looks right? (the Tinygains are just so I can monitor the levels)
I just updated to latest MODEP in this thread MIDI clock seems not working. I seem to think that there is a way to set a global bpm here but am not seeing anything that would do that. I am a bit lost here, admittedly.
I am trying to use the ALO looper, but the global BPM option is turned on by default and I can’t run it in free-running mode. Is it somehow possible to disable the global BPM option in Modep?
